Use this task to view TCP statistics for a Segmented Management Instance.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Mgmt Instance.
  3. Select Stats.
  4. Select the IP/IPv6 TCP tab.
IP/IPv6 TCP Field Descriptions
Use the data in the following table to use the IP/IPv6 TCP tab.
Name
Description
IPVersion
Shows the IP address version as ipv4 or ipv6.
ActiveOpens
Shows the active open TCP connections statistics.
PassiveOpens
Shows the passive open TCP connections statistics.
AttemptFails
Shows the TCP connection attempt failures statistics.
EstabResets
Shows the TCP connection esablished resets statistics.
InSegs
Shows the input segments statistics.
OutSegs
Shows the output segments statistics.
RetransSegs
Shows the retransmit segments statistics.
InErrs
Shows the input checksum errors statistics.
OutRsts
Shows the output resets statistics.
InCsumErrors
Clear
Specifies to clear the statistics. Default is false.
